Gear speeds for Farmall H
Frank in WV
10-18-2005 08:17:45
Is there any difference between gear speeds on the Farmall H during its production? I am being told that you could have 3 different ratios or speeds on an H depending on distillate or gas engine and year of production. I was under the assumption that at best there may have been one gear change on the transmission, ie. 1st being 1 1/2 mph vs 2 mph as an example.
Please advise.
Jeff in ID
10-18-2005 09:26:03
 Re: Gear speeds for Farmall H in reply to Frank in WV, 10-18-2005 08:17:45
The book I have lists the gears for the H as follows (MPH), First 2 1/2, Second 3 3/8, Third 4 1/8, Fourth 5 1/8, Fifth 15 5/8 with Reverse 2 7/8. For the Super H, First 2 5/8, Second 3 3/4, Third 5, Fourth 6 5/8, Fifth 16 1/4 and Reverse 3 1/4. It also mentions about a 2-4 HP difference between Gas and Dist. (Less power with Dist.) which might account for a slight speed difference in gears between tractors. I own a 1940 H and a 1951 H and they both run at the same speeds in the same gears.
RustyFarmall
10-18-2005 08:26:28
Distillate or gasoline all used the same gears. There was an optional one mph low gear, as well as an optional seven mph fourth gear. The super H had the seven mph fourth gear standard, and I believe other gears may have been faster as well.
earlschieb
10-18-2005 08:34:50
 Re: Gear speeds for Farmall H in reply to RustyFarmall, 10-18-2005 08:26:28
Rusty, I have an H, with the X1F suffix, as for fast fourth, and also have a 54 Stage II SH, the H will flat run off from the Super in fourth, as in almost 50 percent faster, both on 13.6 x 38 rubber, both running stock rpm. I wonder why?
DWV
10-18-2005 16:33:10
 Re: Gear speeds for Farmall H in reply to earlschieb, 10-18-2005 08:34:50
Earl the SH 4th gear is slower than the high speed 4th in a H. Which is what your experiencing.
RustyFarmall
10-18-2005 09:14:57
That one is a mystery, maybe not all super Hs had the faster gears?
muggsw6
10-18-2005 11:10:34
 Re: Gear speeds for Farmall H in reply to RustyFarmall, 10-18-2005 09:14:57
As far as i know,supers were faster in every gear,than straights. In m/w-6 supers were 6 1/4 or 6 1/2 in 4th.
