Farmall A carb issue in the future?
Kendog
10-18-2005 08:41:34
As I restore a 1940 A, I notice that the current carb is a Zenith/Bendix, # 124758 / 374203R92. The nearest match my research shows is the 12475 / 374203R91, specified for the Farmall C-123.
The tractor runs except quite rich, but currently all of the jet adjuster screws are locked up. I will dip and rebuild it, and install it in the spring. Do any of you carburetor gurus forecast any mixture problems / rejetting needs since the C-123 is a more powerful motor?
Thank you.
RustyFarmall
10-18-2005 09:24:50
 Re: Farmall A carb issue in the future? in reply to Kendog, 10-18-2005 08:41:34
Probably won't ever notice any difference, but if you use the right kit, the carb can be rebuilt to the specs desired for your tractor. Send me an e-mail.
Kendog
10-18-2005 12:40:15
 Re: Farmall A carb issue in the future? in reply to RustyFarmall, 10-18-2005 09:24:50
RustyF- My email is down. Please contact me at ken@superfetch.com with your thoughts and info. We'll correspond tomorrow. Thank you, Ken.
RustyFarmall
10-18-2005 13:06:17
 Re: Farmall A carb issue in the future? in reply to Kendog, 10-18-2005 12:40:15
Done.
