Super C - taking steering mechanism apart?
leon
10-18-2005 17:29:10
OK, I have the vertical steering shaft with worm wheel assembly out of the front housing and have removed the through bolt, but how do I get the shaft out of the assembly? Shouldn't I be able to support the lower bearing cover and press/beat the shaft down through the assembly? It sure is tight! Will this removal method damage the lower bearing?
gene bender
10-19-2005 03:32:02
 Re: Super C - taking steering mechanism apart? in reply to leon, 10-18-2005 17:29:10
Like HAAS saya be carefull as many of the seal housings havebeen broken. Dont know why but some come apart harder than others.
Haas
10-18-2005 18:32:24
I have used an oak block and a hammer to get them apart. However, better to use a bearing press. The fit on these is not real tight as compared to some pressed fits. Careful with the seal holder. They are easily broken.
