farmall B or BN
schultztec
10-18-2005 18:17:36
Hi,
I just picked up a 1940 farmall B. However it has a single front wheel. Is this actually an BN .. Any help would be appreciated.. THX
Schultztec
MJ in the UK
10-19-2005 09:09:36
 Re: farmall B or BN in reply to schultztec, 10-18-2005 18:17:36
I have a 1940 B with a single front wheel as most of the Bs Hs and Ms imported into the UK in the 1940s had single front wheels for going down the ridged potato rows. Having said all that most of the Hs and Ms were fitted with the wide front axles. At the same time most of the imported funny green and yellow ones were single front wheels. MJ
Red Dave
10-19-2005 05:18:15
Both B's & BN's were available with a choice of two different sized single wheels or the twin front wheel tricycle style.
DaveBN nailed the easiest way to tell a B from a BN.
chuck Bolton
10-18-2005 19:31:37
i believe that the single front wheeled tractors were used in irrigated fields-- i have seen many older models in the southwest. the single wheel would run in the furrow better than a tricycle front end with two wheels -- and it didnt collect the mud as badly--tho i have seen them well caked--they continued to roll
old
10-18-2005 18:30:37
The BN isn't as wide in the rear as a normal B is. So no unless the rear end is norrow its still just a B
schultztec
10-18-2005 18:52:17
 Re: farmall B or BN in reply to old, 10-18-2005 18:30:37
thanks for the info
schultztec
schultztec
10-18-2005 18:56:51
 Re: farmall B or BN in reply to schultztec, 10-18-2005 18:52:17
old,
Could you explain the single front wheel on this tractor, was it just an option back then, most of the B i see on this site all have two wheels ?? thanks
schultztec
Dave BN
10-18-2005 19:04:57
 Re: farmall B or BN in reply to schultztec, 10-18-2005 18:56:51
Yes, single front wheel was an option on many of the tractors of that era IH and others. Easiest way to tell a B from a BN is that there is a space between the right fender and the right seat support on a B. The BN right seat support is right up against the right fender. Dave.
schultztec
10-18-2005 19:15:41
 Re: farmall B or BN in reply to Dave BN, 10-18-2005 19:04:57
great, thanks for the info
schultztec
