Farmall A B and C engines
oldcar29
10-19-2005 08:12:53
Are these engines the same size and interchangeable???
Thanks
Bus Driver
10-19-2005 10:15:37
 Re: Farmall A B and C engines in reply to oldcar29, 10-19-2005 08:12:53
The C runs considerably higher RPM. I have no parts catalog for the C, but would bet that the C has a different camshaft to make the torque peak at higher RPM.
cat
10-27-2005 08:39:49
 Re: Farmall A B and C engines in reply to Bus Driver, 10-19-2005 10:15:37
dont lisin to bus driver he gost wuns you to buy parts
Nat
10-19-2005 08:32:01
They're interchangeable, but they're not the same. The most glaring difference is that a C engine block has provisions for a hydraulic pump. Neither the A nor B have hydraulics.
captaink
10-19-2005 12:54:21
 Re: Farmall A B and C engines in reply to Nat, 10-19-2005 08:32:01
You are correct on the A and B, but I believe the Super A has provisions for a pump also...
David Schumacher
10-19-2005 12:35:01
Thanks so much fellas.
Dave
