T/A on Farmall 400
Carp
10-19-2005 09:26:14
I just had a crazy idea. I have a 400 with the t/a shot. The teeth on the input shaft, output shaft and the planet gears are missing in action. The crazy idea I had was to sneak in there and weld the input shaft to the planet gears and the planet gears to the output shaft so that it is basically direct through (No T/A).
Has anybody heard of this being done or does it sound plain crazy.
the tractor vet
10-19-2005 14:50:01
 Re: T/A on Farmall 400 in reply to Carp, 10-19-2005 09:26:14
Carp why don't ya take a run over to Larry Jordan's and see what he has he has a bunch of parts and my have what ya need reasonable. HE ain't far from ya If you know where Johnson's where then he is a few miles east over the Pa. line and just off old 40 to the north up a small side road.
mbnok
10-19-2005 14:49:36
Generally when the T/a is shot they go ahead and work in direct, just not in the lower range. Is it not moving in either range?
chadd
10-19-2005 15:25:17
 Re: T/A on Farmall 400 in reply to mbnok, 10-19-2005 14:49:36
Since the input shaft gears and all of the planet gears are shot, I don't think it would work in either range. I think it only works in one range if the sprague clutch is shot.
captaink
10-19-2005 12:52:24
If you're set on not fixing the TA, I believe others here have stated there is a kit available with a straight through shaft that will be a better fix and fit right in.
Carp
10-19-2005 13:09:20
 Re: T/A on Farmall 400 in reply to captaink, 10-19-2005 12:52:24
That defeats the purpose. The parts to eliminate the T/A are almost as much as replacing the T/A and you still have to tear it down. If I was going to do that I would just replace the T/A.
I am really looking for a repair that will allow me to use the tractor until I can afford to replace the T/A
Thanks
chadd
10-19-2005 15:22:57
 Re: T/A on Farmall 400 in reply to Carp, 10-19-2005 13:09:20
The only problem with your welding idea is that once you have welded it up, I doubt anyone would give you a core charge for yours, which makes replacing it that much more expensive. Although, if I am wrong (most likely), someone let me know.
ejr-IA.
10-19-2005 09:49:59
I think you can weld just the planet gears to make it work.
steveormary
10-19-2005 10:20:47
 Re: T/A on Farmall 400 in reply to ejr-IA., 10-19-2005 09:49:59
Carp
The TA makes the tractor you know.
steveormary
Carp
10-19-2005 13:10:02
 Re: T/A on Farmall 400 in reply to steveormary, 10-19-2005 10:20:47
The T/A is nice to have, but not necessary for what I do.
Carp
10-19-2005 13:10:08
