Re: Removing injection pump on a MD
Janicholson
10-19-2005 13:52:14
Make sure you are on compression with #1 by putting the engine in gasoline starting settings, ignition off, and pulling #1 sparkplug. Then, with a short piece of garden hose stuck in the spark plug hole, rotate the engine with the crank till air blows out of the hose. Then align the marks. Otherwise it could be 180 degrees off.
JimN
