Order Farmall Cub Parts Online
Cub low boy
Jay Chrisman
10-19-2005 22:04:02
I am working on a cub for a guy, tune up. It had a bad ignition switch and points. I changed all that. My question is does it need a resistor between the switch and the coil? it is a 6volt tractor. thanks
Jay Chrisman
10-20-2005 21:35:11
 Re: Cub low boy in reply to Jay Chrisman, 10-19-2005 22:04:02
I put it all together today, New switch,new coil,6v,new points and condinser,no resistor . starts and runs great. thanks guys ps when I got the cub it had a resistor on it ?? don't know why.
Nat
10-20-2005 05:00:38
No, not unless you put some weird 3V coil on it...
Resistors are only necessary if you do a 12V conversion, and don't change out the old 6V coil.
Slappy
10-20-2005 03:19:32
If the wiring is an original 6V positive ground system, there should be either a voltage regulator or cut-out, but no external resistor that I'm aware of. A common problem is that many of these tractors have electrical systems have been cobbled together over the years, so what you may be working with now is anyone's guess.
