300 U Clutch?
rmz290
10-20-2005 11:53:59
My 300 U will give me a hard time shifting every once in a while. To switch gears I have to pull th TA. It seems like the clutch pedal does not have enough travel. For example when it's going down a small hill and you go to shift to reverse. It seems like everything is locked up until you pull the TA, which then frees it up. Is this an adjustment issue with the main clutch? I have not tried adjusting anything yet.
Thanks!
Hugh MacKay
10-20-2005 12:23:03
 Re: 300 U Clutch? in reply to rmz290, 10-20-2005 11:53:59
rmz290: Read the advice given to Joe by Jim and myself.
Joe Kimbriel
10-20-2005 12:02:48
Sounds similar to my problem.
