2444 wont start
keith talley
10-20-2005 13:21:49
When I turn the key the oil light comes on, showing there is power, but engine will not turn over or not one thing. Just purchased, have manual ordered, but what can I do in the interm.
Keith Talley
El Toro
10-20-2005 17:47:19
 Re: 2444 wont start in reply to keith talley, 10-20-2005 13:21:49
You can start the tractor by shorting across the
solenoid with a screwdriver. Need to have the transmission out of gear and brakes set. Switch needs to be on. It may not start if there's no voltage to ignition. It should crank
the engine. You can trace the problem later if it does starts. Hal
Nat
10-20-2005 14:06:39
The starter system is pretty simple.
There's a big fat cable going from the battery + to the starter solenoid, and a big fat cable from the battery - to the tractor's frame. Sometimes these can get corroded to the point where the small electrical stuff will work, but the starter can't draw enough juice to turn over. Make sure these are clean, solid, and well connected on both ends.
There's also a small wire running from the starter key (or button depending on the tractor) to the starter solenoid. When you turn the key (or press the button), electricity goes down this wire and activates the solenoid to make the starter turn over. Make sure you have voltage here when you turn the key.
the tractor vet
10-20-2005 14:03:13
Do you have power to the starter button ?? is the clutch safty switch working ?? and is the juice getting to the selenoid???, then it should start.
