stages of a super H
tn terry t
10-20-2005 18:14:35
would someone please explain to me about the stages of the super h? theres an h up the road that has super decals on it . but this one has a belly pump on it. i havent stoped to check it out but i can see from the road it has galv. pipe running to the rear from the belly pump thanks terry t
Bob M
10-20-2005 18:46:55
 Re: stages of a super H in reply to tn terry t, 10-20-2005 18:14:35
A Stage 1 SH will have belly pump hydraulics and the battery box under the gas tank. The serial number will be 19233 or below.
Stage 2 has live hydraulics and the battery box beneath the seat. The S/N will be 19234 or higher.
Both stages will have 164 engines (look for "C164" cast in the upper right rear of the engine above the oil filter) and disk brakes.
Note however there's plenty of regular H's that have been re-decalled with "Super" decals. Serial numbers and casting date codes are the true indication whether a particular SH is a truly a super.
tn terry t
10-20-2005 19:46:26
 Re: stages of a super H in reply to Bob M, 10-20-2005 18:46:55
thanks man one more question does the stage i have power steering?
Wayne Swenson
10-20-2005 19:49:22
 Re: stages of a super H in reply to tn terry t, 10-20-2005 19:46:26
No power steering.
tn terry t
10-20-2005 20:01:39
 Re: stages of a super H in reply to Wayne Swenson, 10-20-2005 19:49:22
thanks wayne i was wanting to take a peek at a super with power steering to get some ideas and tips for putting PS on my 49 inwhich now has live hydro and a frontend loader with tilt bucket or in my case tilt hayspear
Bob M
10-21-2005 04:36:00
 Re: stages of a super H in reply to tn terry t, 10-20-2005 20:01:39
If your H has a live pump and you don't object to doing some sheet metal mod's to the hood to provide space, a CharLynn PS kit can be adapted to install on an H.
Punch below for CharLynn installation instructions for an M.
tn terry t
10-21-2005 18:34:02
 Re: stages of a super H in reply to Bob M, 10-21-2005 04:36:00
thanks!!!!! very much friend yea i have a hyrdo pump hanging off the crankshaft through the hand crank hole i dont know how big of a pump i have but it will sure pick up more than i can handle with this ole h sure need to figure this power steering out aint worried about the hood now shouldnt i be able to "tee off"the main pressure line through a priorty valve to the charrlynn unit then run a return line to my tank?
