Order Farmall Cub Parts Online
1951 Cub Choke Rod Hookup to carb - Help
Kurt in Va Bea
10-21-2005 05:49:43
All, I just bought a '51 cub and cannot figure out how to hook up the choke rod to the carb. When I got it, the choke rod was put in backwards (lever was on the inside). I rebuilt the carb according to the IH direction which puts the lever on the outside. So now the $64,000 question, how do I hook the rod (which runs down the backside of the carb) to the level which is now outside. I have not been able find a good picture or anything of how to hook up the choke to the carb. I've look at IH manuals and still have not found anything. thanks for the assistance.
George Willer
10-21-2005 06:50:39
 Re: 1951 Cub Choke Rod Hookup to carb - Help in reply to Kurt in Va Beach, 10-21-2005 05:49:43
Turn the choke around. The lever the rod is attached to belongs on the engine side.
George Willer
Kurt in Va Beach
10-21-2005 08:29:19
 Re: 1951 Cub Choke Rod Hookup to carb - Help in reply to George Willer, 10-21-2005 06:50:39
Thanks George! just one question, why then does the IH sheet that comes with the carb rebuild kit and pictures of the IH carb I have seen have the lever on the outside?
Nat
10-21-2005 12:23:58
 Re: 1951 Cub Choke Rod Hookup to carb - Help in reply to Kurt in Va Beach, 10-21-2005 08:29:19
Technical documentation is not always 100% accurate, and since the tractor design is over 50 years old, there's little need/inclination to correct it.
