Fluid for Farmhand loader?
clair fitch
10-21-2005 09:00:43
I have a Farmhand F11 loader on my 504. I only use it once a week or less for half an hour. Do you have to periodically change out the fluid in the loader reservior? If so how often? What type of fluid do I need to use? Thanks in advance.
Hugh MacKay
10-23-2005 03:06:57
 Re: Fluid for Farmhand loader? in reply to clair fitch, 10-21-2005 09:00:43
clair: You speak of loader resovoir, Are you using tractor factory hydraulics or do you have a front mounted pump? Front mounted pump system may not require hytran. You may get by with cheaper oil.
As for changing hydraulic oils, no real reason to ever do it unless oil becomes water saturated. Filters will catch dirt, drain plug magnets will catch metal.
As others have said, leaks and hose breakage will change the oil fast enough.
clair fitch
10-23-2005 16:49:27
 Re: Fluid for Farmhand loader? in reply to Hugh MacKay, 10-23-2005 03:06:57
The loader hydraulic pump is separate from the tractor hydraulic pump. It is attached to the rear PTO. The reservior is separate from the tractor reservior. Will HyTran work or will regular hydraulic oil work?
Hugh MacKay
10-24-2005 01:59:41
 Re: Fluid for Farmhand loader? in reply to clair fitch, 10-23-2005 16:49:27
clair: You just need a good grade hydraulic oil for that loader. The tractor factory system should have Hytran.
Sloroll
10-21-2005 11:44:25
third party image
Just blew a hose on my 504, Figure that was an oil change.
Sloroll
10-21-2005 11:43:57
Nebraska Cowman
10-21-2005 09:23:05
I use Hy-tran and it seems like those old Farmhands leak enough they change their own oil. But yeah, I suppose one should change it once in a while.
Allan in NE
10-21-2005 09:37:24
 Re: Fluid for Farmhand loader? in reply to Nebraska Cowman, 10-21-2005 09:23:05
Yepper,
Usually too busy pourin' in to think about drainin' out. :>)
Allan
