Carb rebuild; stubborn brass jet and well vent
Kendog
10-21-2005 10:06:36
I don't think this carb has been apart since installed in 1940. The tiny brass idling jet and well vent inside will not budge after substantial pb blaster or heat. The ears for the screwdriver on each are chipping away also.
I may need to drill them out. Any tricks? Reverse tap perhaps?
Thank you.
gene bender
10-22-2005 03:23:13
 Re: Carb rebuild; stubborn brass jet and well vent in reply to Kendog, 10-21-2005 10:06:36
You dont have to remove them just blast them with cleaner and compressed air.
Wayne Swenson
10-21-2005 19:27:15
What tractor model are you working on?
I have drilled out the jet (careful not to go too deep!) and used a # 5-40 tap to clean the threads. See your local gunsmith or find a REAL hardware store & purchase a tap; they are not commonly found in tap & die sets.
RustyFarmall
10-21-2005 10:23:16
If it isn't broke, don't fix it. Leave 'em in there. You can still do a good job of cleaning.
