polarizing
Alannpa
10-22-2005 04:04:46
When polarizing, which post should spark, or doesn't it matter?
John T
10-22-2005 07:00:33
 Re: polarizing in reply to Alannpa, 10-22-2005 04:04:46
Alan, Gene has ya covered and I will add a bit so you understand just what "polarizing" does.
As he mentions, you can momentarily flash jump the BAT and GEN (or ARM) terminals together on a Class A system and it ought to spark cuz youre passing current through the generator to ground. If the VR isnt easy to get to, the same things accomplished if you momentarily flash jump ANY HOT ungrounded battery voltage source, such as the BAT terminal on the VR or else the starter/battery post etc. DIRECT TO the Generators Armature post.
Polarizing happens cuz when you pass current through the generators Field windings it imparts a residual magnetism into the soft iron field poles with the correct magnetic North/South polarity, so when the armature begins to turn inside that magnetic field, the induced voltage has the corresponding correct +/- electrical polarity to charge the battery.
To insure the field has a good ground when polarizing, one can have it temporarily dead grounded to case/frame.
Good luck n God Bless
John T
leon
10-22-2005 14:18:49
 Re: polarizing in reply to John T, 10-22-2005 07:00:33
John T
What do you mean by "Class A system"?
Jim Becker
10-22-2005 16:10:19
 Re: polarizing in reply to leon, 10-22-2005 14:18:49
There are 2 basic ways a charging system can be wired. An "A" circuit field is connectesd to the hot brush inside the generator. The F terminal has the ground end of the field. The regulator works by controlling the ground of the F terminal.
A "B" circuit is wired to opposite way. The field circuit is grounded inside the generator. The hot end is connected to the field terminal. The regulator works by controlling voltage at the F terminal.
I hope that was adequately clear. The troubleshooting and polarizing procedures differ because of this wiring difference. I have never run into a "B" circuit system.
gene bender
10-22-2005 06:45:40
Batt term to ARM on gen and it doesent make any diff which post sparks.
