Fast Hitch Size
Dave R. in So.
10-22-2005 10:25:33
Is there a difference in width between the fast hitch on a Farmall 200 vs a Farmall 400. A sale has several FH implements on it along with a Farmall 200. I assume that the implements were used with the 200. I was wondering if I could use those implements with my Farmall 400. I know there are different sized prongs but I am not sure if the distance between the sockets is different. Thanks in advance for any info. Dave
Wardner
10-22-2005 10:38:23
 Re: Fast Hitch Size in reply to Dave R. in So. IL, 10-22-2005 10:25:33
The spacing is the same on all two prong fast hitches. You will need 1/2" thick spacers to make the skinny prongs fit the larger sockets. These spacers can be easily made or you might be able to find a pair made by IH for this purpose. You will see them in some parts books.
Dave R. in So. IL
10-24-2005 10:39:24
 Re: Fast Hitch Size in reply to Wardner, 10-22-2005 10:38:23
Thanks for the info. I doubt that I will be able to afford the disk that I want but at least I know that it will fit my tractor.
Dave
