Gene37: You didn't say whether you just wanted to bring your A up to SA horsepower specs or are you wanting to convert the engine to work in a SA? There is a difference, most of this has been covered by Dave, Jim and Charles. If you are just trying to bring your A up to SA hp specs., I wouldn't put a whole lot of money into this project. I have used all these offsets in my time, and could never see a whole lot of difference in power between A, SA, 100, 130 and 140. I know the IH specs and Nebraska tests will tell you there is a difference, but how great and can you pick it out from the seat working the tractor. Currently I have a SA, 130 and 140. SA has C-113 engine and others have C-123. All have factory original piston and sleeve kits. I have a 17 shank S-tine field cultivator, if you allow that cultivator to drop without control, it will stop anyone of these tractors dead in it's tracks. Not sure it wouldn't stop an H. I must use depth control with this cultivator. My Super A will lug this cultivator all day just as fast as 130 or 140. I can see very little difference, no matter which tractor I use. I can tell you 130 is down a bit on compression, but SA and 140 are right up there. If I were to give the edge to any of the three it would go to 130. Believe me it would be a hard call.
