IH Touch- Control Fluid/ C-32 Loader
Joe in VT
10-22-2005 16:41:18
Today I installed a C-32 Loader on to my Super C.
My next step is to connect the plumbing and see if it works !
My Operators Manual says to use IH Touch- Control Fluid .....Is that the same as Transmission fluid (Dexron 3) ? What should I use ?
Any Tips ??
tfringo
11-27-2005 09:29:39
 Re: IH Touch- Control Fluid/ C-32 Loader in reply to Joe in VT, 10-22-2005 16:41:18
I am trying to identify a loader I purchased for my Super C. Any chance you could send a picture of yours to my email address....tfringo@aol.com.
Mine is real nice, just needs a little TLC and It will be put on my tractor.
CNKS
10-22-2005 18:57:32
It is not Dexron 3, use HyTran or a hydraulic fluid that meets Hytran specs.
JoeinVT
10-22-2005 19:01:07
 Re: IH Touch- Control Fluid/ C-32 Loader in reply to CNKS, 10-22-2005 18:57:32
Thanks CNKS I guess I will take a trip over to the Tractor Supply
El Toro
10-22-2005 18:15:44
They call it Hy-Tran now. Hal
JoeinVT
10-22-2005 18:57:24
 Re: IH Touch- Control Fluid/ C-32 Loader in reply to El Toro, 10-22-2005 18:15:44
Hal,
Is Hi -Tran the same as Auto Transmission Fluid ?
JoeinVT
El Toro
10-23-2005 03:43:41
 Re: IH Touch- Control Fluid/ C-32 Loader in reply to JoeinVT, 10-22-2005 18:57:24
I knew that too, thanks, Hal
