Where can I find this spring for governor?
CrAzY CoOtEr
10-23-2005 10:07:52
I have a 1940 H and I need the main spring that actuates the throttle. It has a hook on one end and a pin goes through the other. Does anyone know where I could get one, and what is the cost I am looking at? Thanks ahead of time!
Wayne Swenson
10-23-2005 14:03:57
 Re: Where can I find this spring for governor? in reply to CrAzY CoOtEr, 10-23-2005 10:07:52
You can find one at NAPA & it is a bit stronger than original so your engine speed can increase a bit.
RustyFarmall
10-23-2005 12:51:49
I am pretty certain that spring you describe was discontinued, and replaced with the spring with a hook on each end. Like little john said, you should be able to get it at your local Case-IH dealer.
CrAzY CoOtEr
10-23-2005 17:14:15
 Re: Where can I find this spring for governor? in reply to RustyFarmall, 10-23-2005 12:51:49
Whew! Thanks! That's good to know! Special thanks to rusty, you've been a big help since the get go!
little john
10-23-2005 10:55:47
 governor spring in reply to CrAzY CoOtEr, 10-23-2005 10:07:52
I got one for a '44 "H" recently at the Case IH dealer. This one had a hook on each end. Seems the cost was $5.00 or so.
