Dumb C timing question-Sorry
Dave BN
10-23-2005 13:22:06
Sorry to ask a dumb question but I can't get this thru my thick head. While installing a new distributer cap today noticed that my distributer is installed 180 degrees from what it should be. I know this for two reasons. The wire for #3 cylinder is on the post marked #1 on the cap. That doens't matter as long as you are aware of it. The real problem is that the zerk fitting for the distributer shaft is pointing towards the engine and there is no way to get a gun on it. I want to be able to grease this but the engine runs so good I hate to mess with it. Here's the question, if I mark the position of the rotor and spin the body of the distributer 180 degrees will I still be in time? Thanks for any help, Dave.
El Toro
10-23-2005 17:01:24
 Re: Dumb C timing question-Sorry in reply to Dave BN, 10-23-2005 13:22:06
It probably would be easier to do as old has suggested. Remove No1 plug and bring the piston
up on the compression stroke to TDC. Your timing mark on the flywheel should be aligned with the pointer when piston is at TDC. Then pull distributor and set at No1. Then put No1 plug in the cap and reconnect the rest 3-4-2 . I think it was timed on No4 piston and you can leave it there. Hal
old
10-23-2005 13:35:02
Well if you spin the dist and then change the plug wires you will be ok. You should probably get it at TDC on number 1 and then line up the nibble for number one on the dist cap and hook the wires the way they where when new.
