'42 M cam shaft
bitbythebug
10-24-2005 15:35:03
The cam gear retaining nut came loose and the gear walked out and ate up the cam key and keyway in the cam. I am wondering if there is any aftermarket cams I could by that would increase the horsepower? Such as a pulling tractor cam. And how useable is such a cam for pto uses? And what about the cost? Thanx, Dan
Andy Martin
10-24-2005 16:35:59
 Re: '42 M cam shaft in reply to bitbythebug, 10-24-2005 15:35:03
There are aftermarket cams available.
El Toro
10-24-2005 16:30:10
You can try Wolverine Blue Racer Performance Cams
to see if they have cams for farm tractors at 1-800-248-0134. You may be better off to locate a good used cam. Hal
supermpuller
10-24-2005 19:04:40
 Re: '42 M cam shaft in reply to El Toro, 10-24-2005 16:30:10
Get a 450 cam they are still around brand new.
