Farmall 300 cracked block
Andrew Z
10-24-2005 17:03:40
I saw a 300 on the side of the raod today stoped and it looked pretty good till I saw the craked block. It's cracked right below the "indent" in the block on the left side of the tractor (the carb side). The crack is about 4 or 5 inches long. I can see the rod sticking throught the block. What could have caused this to happen. Can this be fixed? Or would it need a new block? Thanks for the help Andrew Z
Dr.EVIL
10-25-2005 08:46:24
 Re: Farmall 300 cracked block in reply to Andrew Z, 10-24-2005 17:03:40
Seems to be entirely too common on Super H/300/350's. Rod bolts breaking is also another cause of ventilated blocks on these engines. Unfortunately these tractors were too little for most of the things they got asked to do and got run VERY hard in the early stages of their lives. I know My Super H was too small for about everything It got hitched to when Dad was farming. And if it finally got hitched to something it could handle We shifted UP a gear and pulled it faster and harder!
El Toro
10-25-2005 06:22:45
I would agree with with what the others have said,
buy a good engine or block and rebuild it. Then you know what you have. I doubt if the crankshaft
is salvageable too. A good auto machine shop can determine if it's bent. Hal
K.B.-826
10-24-2005 19:17:50
Rod through the side of the block is bad news. Usually a good sign the engine lost oil pressure or coolant dumped into the oil, rod bearing then seized, and connecting rod broke. I bet there's a lot of damage to that crankshaft. Block could very well be junk, depending if that rod went through any oil gallies or coolant passages. I wouldn't even mess with that engine. Lots of good H, 300, 350 engines out there that you could pick up cheap and bolt in or rebuild.
Michael Soldan
10-24-2005 18:55:26
Andrew, I've heard of guys welding blocks and /or drilling and pinning blocks. This after new sleeve and other repairs. A rod comes through the block when a bearing lets go or a wrist pin breaks and as the engine turns the rod is a loose cannon flying around in there at all angles until it gouges into the wall of the block and "Bang" its through the wall of the block..can be fixed, I'd likely find another block personally, if I have to rebuild its going to be a good block..not to say that some breaks are very successfully repaired...Mike in Exeter Ontario
Dick Davis
10-25-2005 04:12:09
 Re: Farmall 300 cracked block in reply to Michael Soldan, 10-24-2005 18:55:26
Yup, Andrew, Like the other guys said you would be in the market for a different engine. Of course you could own about 2/3's of an orginal SHTA! LOL Sorry guys but we haven't been there for weeks! My nickel Dick Davis
Andrew Z
10-25-2005 07:24:30
 Re: Farmall 300 cracked block in reply to Dick Davis, 10-25-2005 04:12:09
Thanks guys for the replys I think I going to pass on that one. Andrew
