Casting code
biggerred
10-24-2005 18:02:22
what year is "W" in a casting code? Sorry for such a basic question but we just moved and some of my books are still packed up.
Jim Becker
10-24-2005 20:37:32
 Re: Casting code in reply to biggerred, 10-24-2005 18:02:22
Yeah, '51, unless it is '73.
Howard Magathan
10-24-2005 19:29:33
What is a casting code? As you can tell, I"m a new tractor owner.I have a farmall 200 with a(2) point fast hitch and (5) implements. How would you go about finding the modle #"s and the year of each piece? I would like to know so I can find the right info. to fix them up. THanks for any info.
Randy in NE
10-25-2005 04:17:46
 Re: Casting code in reply to Howard Magathan, 10-24-2005 19:29:33
The casting code is a date that was engraved in the mold for some of the larger castings such as the rear-end/transmission, block, and torque tube. It would look like 10*25*W which is October 25, 1951. They used a letter for the year. A "ZA" would be for 1954 and an "A" for 1953, etc. The implements did not have casting codes. The best thing would be to find an owners manual for the implements for the 200. I had one for the implements for my C until I put it away prior to the cleaning lady showing up. It is now safely tucked away in my house somewhere.
Stan(VA).
10-25-2005 04:58:31
 Re: Casting code in reply to Randy in NE, 10-25-2005 04:17:46
Randy,
Y is 1953
Z is 1954
A is 1955 as they started over again.
1951 is the odd-ball year as they started out with U and changed over to using W (in mid-March I believe from a tractor I saw with both castings).
Stan(VA).
Randy in NE
10-25-2005 10:56:24
 Re: Casting code in reply to Stan(VA)., 10-25-2005 04:58:31
You are right. I miss read my cheat-sheet.
RustyFarmall
10-25-2005 06:06:11
According to some sources the letter U and V were never used, but I also have seen the letter U in a casting code.
Jim Becker
10-25-2005 20:57:48
 Re: Casting code in reply to RustyFarmall, 10-25-2005 06:06:11
I have seen a number of U codes also a couple V codes. V seems to be pretty rare, maybe just one guy working at one foundry? As I recall, the last V I saw was on the belt pulley housing of either an H or M.
Paul in Mich
10-24-2005 18:07:01
1951
RustyFarmall
10-24-2005 18:04:24
1951
Bigdog
10-24-2005 18:04:06
1951
