super M bisk brakes
david bell/chai
10-26-2005 07:51:02
hello farmalls, right hand side is frozen or locked up on my tractor. left side turns freely though. when i take the brake cover off, what do i do next to fix this ?? thanks to all replys. david/chainsaw
david /chainsaw
10-26-2005 15:09:07
 Re: super M disk brakes in reply to david bell/chainsaw, 10-26-2005 07:51:02
i appreciate yalls help. i'm in waco tx. i'll try to get this cover off in the next few days and see what she looks like. when i do finish, i'll post the results. thanks again for all of yalls help. david /chainsaw
Randy in NE
10-26-2005 08:02:22
 Re: super M bisk brakes in reply to david bell/chainsaw, 10-26-2005 07:51:02
I took one of the disk brakes apart on my Super C this summer. Once you have the cover off you should be able to get the pins out for the linkage to the brake pedal. Then everything should slide right off the brake shaft. I just cleaned everything up. Just make sure that all of the brake/disk surfaces are clean and free of oil and rust.
david/chainsaw
10-26-2005 08:14:27
 Re: super M disk brakes in reply to Randy in NE, 10-26-2005 08:02:22
thanks randy.
Janicholson
10-26-2005 08:49:41
 Re: super M disk brakes in reply to david/chainsaw, 10-26-2005 08:14:27
As described, it is not rocket science in there. Clean with Brake-Clean, or other spray solvent. don't breath the dust, it is asbestos laden. lube the three balls in the wedge plates with a -thin- coat of moly anti sieze or silicon grease, not oil.
Use Tri-flow spray on the linkage pivot points, but don't get it on any surfaces. Sanding the friction surfaces will clean them up. sand around and around, not across the surfaces, and evenly.
The little rubber boots on the front keep water out to a degree, but use is the best preservative.
If the friction plates are even half worn compared to new, the brakes may not have enough adjustment to work well. Expect two years or so out of the cleaning.
Been in there a lot.
JimN
Kelvin
10-26-2005 09:23:29
 Re: super M disk brakes in reply to Janicholson, 10-26-2005 08:49:41
I suggest you try without any moly or any other kind of lube-just reassemble the plates and balls clean and dry. grease picks up the dust and that makes its own problems.
Janicholson
10-26-2005 11:04:48
 Re: super M disk brakes in reply to Kelvin, 10-26-2005 09:23:29
Dear Kelvin, In some climates dry works. I don't know where this tractor is, but in every midwest location I've been the humidity rusted up the balls, ramps, and pivots to the point of non function. Dust and dirt were secondary considerations. If a thin coat is used it won't migrate, and protects from corrosion.
IMHO.
JimN
