Bermuda Ken seal #
Bijll Geer
10-26-2005 21:17:01
Ken.
Will you send me a number for a seal for the pto on a farmall H? My parts house sells nat.or C.rawhide. Thanks Bill
bermuda ken
10-27-2005 05:40:07
 Re: H pto seal numbers here!!! in reply to Bijll Geer, 10-26-2005 21:17:01
IH used 2 different PTO's on the H depending on the tractor serial number. The serial number break is at 118000. Is your tractor serial number above or below this?? The two seals are not interchangable.
The lower serial number tractor pto units use a seal CR16275. The higher serial number tractors PTO use seal CR13696.
gene bender
10-27-2005 03:46:53
 Re: Bermuda Ken seal # in reply to Bijll Geer, 10-26-2005 21:17:01
just get measurements of old seal and give them to whereever you get a new seal. just that simple.
