H Motor is Mounted
MagMan
10-27-2005 16:20:49
Yea I finally got the new motor in the H today. I was looking at the cherry picker on the Gravel floor and scratching my head and My wife came out and said get out of the way and with a little guidance she got that puppy right in and lined up perfect like she had done it 100 times before. COOL Now hopefuly in a few days I will be able to get it finished up and started. Thats if it will run I guess. I decided to get it started and build some oil pressure then let her set till spring untill I am able to get back to doing things again after the up coming surgery.For some reason a body cast or brace just does not sound aplealing to me but hey you got to do what you got to do I guess. So there wont be any rebuilding of any mags in the near future. But I have talked my brother into keeping up the parts bussiness for now. So I will try to have my wife check in from time to time for me to try to keep up with what everyone is doing.
I will keep posting untill its running or I run out of time. LOL JON
Bob Frey
10-27-2005 16:50:33
 Re: H Motor is Mounted in reply to MagMan, 10-27-2005 16:20:49
Get well soon! Keep thinking about that H and you will speed your recovery.
Bob
Good news!! Janicholson
10-27-2005 16:41:58
Well wives are often salvation.
When it is shutdown for the recovery, I recommend a product called LPS corrosion inhibitor to be sprayed into each spark plug hole. This stuff is like a thinest layer of non drying oil to keep even surface rust from forming. I had a Toyota 3TC engine laid up for 7 years and it had zero rust internally and started immediatly after priming the fuel and prepping the installation (in an austin Healy Sprite).
Good luck with the surgery,
JimN
Dick Davis
10-28-2005 05:17:38
 Re: H Motor is Mounted in reply to Good news!! Janicholson, 10-27-2005 16:41:58
Good luck MagMan, hope everything works faster than the doc says! Will appreciate your better half keeping us up to date. My nickel Dick Davis
