Super A hydraulic pump
JRV
10-27-2005 18:46:40
Where could I find a printout that shows the parts of the touch control pump. My friend"s Super A has a leaky pump so he tore it down to rebuild it. I guess the kit he bought has a washer in it that he can"t figure out where it goes.I have a parts catalog for my Farmall 200 that shows the the two different makes of pumps, Pesco and Thompson, but it doesn"t really break them down.Any help would be appreciated. Thanks JRV
CNKS
10-27-2005 20:02:22
 Re: Super A hydraulic pump in reply to JRV, 10-27-2005 18:46:40
Some kits have parts for more than one model of pump, although the Pesco and Thompson kits will be different. If the replacement parts fit, ignore the washer if it wasn't in the pump. I have repaired the one on my C, yours is similar, the parts book does not show a diagram. The leak is caused by the front seal or o-ring, the other parts in the kit have no effect on the leak, but replace them anyway. If the shaft is severely grooved you need a speedy sleeve, if the groove was caused by an o-ring as opposed to a regular seal, you have to enlarge the shaft hole to accept the speedy sleeve.
