My H has a hole in it, Two holes !!
VanO
10-28-2005 11:54:54
Hi All; On the grill of an H there is two holes below the Farmall emblem. I think the pipes behind the grill is call the bolster? There are two holes in this framework cororsponding to the two holes in the grill. What went there?
Thanks, VanO
Wardner
10-28-2005 15:08:44
 Re: My H has a hole in it, Two holes !! in reply to VanO, 10-28-2005 11:54:54
third party image
Here ya go. Picture of bracket and grill should be loading. If not, click on link or go to "Galleries > Parts and Pieces" found on left side of this page
Wardner (no red X)
10-28-2005 15:46:12
 Re: My H has a hole in it, Two holes !! in reply to Wardner, 10-28-2005 15:08:44
third party image
Just figured out how to copy picture from "Galleries". You have to click on "properties" while over the image and select and copy the URL from that page. Then paste it in "Optional Image URL" on the composition page.
captaink
10-28-2005 11:57:05
A brace to the outside end of the frame of a four-row mounted cultivator. Possibly other mounted equipment also.
Allan in NE
10-28-2005 12:19:12
 Re: My H has a hole in it, Two holes !! in reply to captaink, 10-28-2005 11:57:05
Yep,
2-row wide, 6-row narrow cultivators as well as the lift mechanism for the bean cutters. All kinds of nice stuff bolted there. :>)
Allan
RustyFarmall
10-28-2005 14:01:05
 Re: My H has a hole in it, Two holes !! in reply to Allan in NE, 10-28-2005 12:19:12
The framework for the anti-sway apparatus on a McCormick #31 loader attaches to those holes also.
goterdone
10-29-2005 15:17:27
 Re: My H has a hole in it, Two holes !! in reply to RustyFarmall, 10-28-2005 14:01:05
My H has a brakret for the loader bolted there. If you use these holes to bolt something. Dont forget to use a bushing so you wont crush the grill. A piece of 3/8 or 1/2 in pipe about 11/2 in long.
