Farmall A front end part
Retcol
10-28-2005 16:58:20
My mechanic is working on my Farmall A. He noticed the large pin that goes in the center of the front end is bent. He contacted the local CIH dealer to see if he could get the part. The parts man located one somewhere but it is $200 plus. Does anyone know where we can locate a used on in good condtion and how much do they run?
gene bender
10-29-2005 04:41:59
 Re: Farmall A front end part in reply to Retcol, 10-28-2005 16:58:20
That pin is a piece of 1in round with a machined place for the bolts to lock in place on each end. I have one or can make you a new one.
Retcol
10-29-2005 05:03:36
 Re: Farmall A front end part in reply to gene bender, 10-29-2005 04:41:59
What is the cost and where are you located?
gene bender
10-31-2005 03:28:27
 Re: Farmall A front end part in reply to Retcol, 10-29-2005 05:03:36
Did you get the r-mail?
El Toro
10-28-2005 18:15:39
Is that the pivot pin in the center of the axle?
You should post a picture of the pin and where it's located. A good machine shop can probably
make a new pin and even temper it for less than that. Hal
Doug Kieta
10-28-2005 18:10:31
Try Gap Tractor Parts, 1-800-972-7078. They are very reasonable, and will ship anywhere in the world.
