weld on bellhousing?
nofirefarmall
10-28-2005 17:00:19
I'm playing with my 1941 farmall model A and I noticed a wide weld on the bellhousing. I guess its the bellhousing, its between the motor and trans. The weld is about a inch wide and about four inches in front of the trans. Is this factory or did someone break this tractor? Thanks for any info you can give.
Peabody
10-28-2005 18:22:43
 Re: weld on bellhousing? in reply to nofirefarmall, 10-28-2005 17:00:19
As CNKS said, keep an eye on it. But it is fairly common to have a weld in that place on those Cub/A/B/C tractors with no structural frame rails. It will probably give you no problems and outlive all of us!
CNKS
10-28-2005 17:35:53
It was broken, whether or not it hurts anything depends on the quality of the weld -- it is a structural component so keep an eye on it.
