Farmall 504
SMA in NE
10-29-2005 05:59:57
I am looking at a 504. Runs good, 1 good rear tire the other one is shot, fronts are pretty much done as well. The sheet metal is decent although one fender (clam shell) is bent and the piece under the steering wheel and instrument cluster is gone. The 3 pt. top link is missing and the lift arms are similar to those on a Ford although slightly heavier. The lift arms I remember a 504 having included the extendable arm, maybe that was an option. The only thing I feel may be hard to find is the sheet metal piece that is supposed to be under the instrument cluster. The steering wheel is about ready to fall apart also. What are your opinions on this tractor?
DJH
10-29-2005 17:32:32
 Re: Farmall 504 in reply to SMA in NE, 10-29-2005 05:59:57
Was this on an auction? It sounds exactly like a 504 gasser that was on a sale today. I wasn"t there when the tractor sold, but I was told it brought $1,800.
SMA in NE
10-30-2005 16:44:47
 Re: Farmall 504 in reply to DJH, 10-29-2005 17:32:32
Yes it was at an auction. I was there, it did bring $1,800. I did not buy it.
DJH
10-30-2005 17:55:32
 Re: Farmall 504 in reply to SMA in NE, 10-30-2005 16:44:47
Where are you from? I live in the town where the auction was located. Not only was the top link missing, but the casting that the pin goes through was broken. How did the tractor sound? I think a person could have spent a fair amount fixing it up. Did you get anything bought at the sale?
CNKS
10-29-2005 11:48:22
If you want the tractor to use, forget it, probably much more wrong with it than you see now. If you want it as a hobby and have lots of money, don't pay too much for it in that condition. I imagine the fender would not be too hard to find. As to the piece under the dash, Jeff at 317-216-8269 -- jeffsbigdawg@aol.com -- had a new remanufactured one for my 460U. Don't know if he has one for a 504 or not.
Dellbertt
10-29-2005 11:09:10
Unless its a gift, Id pass.
joe/pa
10-29-2005 10:07:53
how much money are they asking for it? what are you wanting to do with it? I like mine, but it's almost too small so it's for sale in the classifides.
El Toro
10-29-2005 06:44:35
If this 504 is the gas version C153 it doesn't have sleeves. The military used these years ago to mow the firing ranges. Hal
Sloroll
10-29-2005 06:10:37
Run from it.
I like my 504 but You will have more money in that one than you can go buy a good one, unless it is being given to you.
