clicking left axle
pl
10-29-2005 15:14:39
I have a Farmall ('A' I think) that just started making a click or clunk sound once every revolution of the left tire. It sounds like it is coming from the area of the axle closer to the frame (rather than the wheel). Any ideas what it might be...and the fix?
Red Dave
10-29-2005 15:39:08
 Re: clicking left axle in reply to pl, 10-29-2005 15:14:39
Might be a loose bolt that holds the wheel to the rim, might be a loose wheel weight, or if you have eliminated those possibilities, it might be a bad bearing in the final drive. To fix it, if it is a bearing, you'll have to remove the final drive to replace bearings.
pl
10-29-2005 16:34:51
 Re: clicking left axle in reply to Red Dave, 10-29-2005 15:39:08
Thanks..... .....
assuming worst case, how do you go about removing the final drive? Is that to the side at the axle, or the rear? Not sure I can tackle this one.
Red Dave
10-30-2005 06:34:56
 Re: clicking left axle in reply to pl, 10-29-2005 16:34:51
The left side final drive on an A is mounted on the left side of the Transmission/differential. It is removed by unbolting it after you remove the rim & wheel. You will probably need a press to get the axle out of the bottom gear.
pl
10-30-2005 07:33:24
 Re: clicking left axle in reply to Red Dave, 10-30-2005 06:34:56
Red Dave;
Thanks for the help.
