Order Farmall Cub Parts Online
Farmall Cub wont start
kkttklw92
10-29-2005 21:03:23
I was plowing with my cub today. I noticed an obvious knocking noise. As I was finishing one row, it just shut down on me. When I tried to restart it, I could get it to turn over but it wouldnt start. And yes, it does have gas. Any ideas?
El Toro
10-30-2005 03:52:18
 Re: Farmall Cub wont start in reply to kkttklw92, 10-29-2005 21:03:23
Gas in the tank doesn't mean it's getting to the carburetor. If it is getting fuel pull off a plug wire and see if have fire to the plugs while someone tries to start the engine. If you have good fire I would check that compression as old suggested. Hal
old
10-29-2005 21:56:07
But does it have spark. Takes 3 things to make and engine run, gas, spark, and compression. All at the right time. I'd make sure it has spark and then go from there.
banjo
10-30-2005 22:01:39
 Re: Farmall Cub wont start in reply to old, 10-29-2005 21:56:07
Just becouse it gets spark does not mean it is getting it at the right time. Had a 5 hp wood splitter that the spring on the points broke but it would still get spark. bout drove me crazy. check the points and condenser to be sure.
