water header
weldor
10-30-2005 05:31:04
Need advice on what proceedures and sealants to use on Farmall H water header to block, water drain plug in the block and the drain pipe at the bottom of the radiator. Not having good luck sealing these from coolant leaks.
MagMan
10-30-2005 14:16:04
 Re: water header in reply to weldor, 10-30-2005 05:31:04
I would say that you want the permatex Gasket sealent. There are two types one hardens and one does not like a one and two. I bought a tube at Napa for the asembley of my H it also comes in a plastic can with a brush about 3.49 I have used this stuff in the auto industry for years on waterpump gaskets and hoses and such. JON
