Looking for Fast Hitch Rocker shaft that goes thro
Calif. Farmall
10-30-2005 16:21:01
My Fast Hitch Rocker shaft is cracked inside the arm it's welded to.It's still holding but it flops the lift cylinder aound. I could cut it out an reweld it however to make it stronger they put the 1.25" shaft through the lift arm and welded it on the outside. If I cut it out it will be too short. Any ideas? Thank's DAN
Janicholson
10-30-2005 16:31:55
 Re: Looking for Fast Hitch Rocker shaft that goes in reply to Calif. Farmall, 10-30-2005 16:21:01
There are a bunch of different systems, we need to know the year/model and maybe the approx production date. to do much helping.
JimN
Calif. Farmall
10-30-2005 20:42:19
 Re: Looking for Fast Hitch Rocker shaft that goes in reply to Janicholson, 10-30-2005 16:31:55
The fast hitch is on a 1953 super C. The part that goes through the seat base.
