F 20 rear wheel bearing
Everett Mi
10-30-2005 16:36:15
Jacked up the rear wheel of the F 20, noticed the bottom of the wheel kicked in a bit. Maybe bad rear wheel bearing? Parts book looks like roller bearing. Anyone done this job? What kind job is this? Is the bull gear pressed on to the axle shaft? Don`t know what I`m getting into. Thanks for any help you can pass on to me Everett
wes in PA
10-30-2005 19:34:43
 Re: F 20 rear wheel bearing in reply to Everett Mi, 10-30-2005 16:36:15
Take the wheel off and remove the small cover, with 4 bolts holding it on, located above where the drawbar attaches. there are 2 large nuts that need to be removed and then the whole axle will pull out. then you can inspect the bearing, race, and axle splines for wear.
Everett Mi
11-01-2005 11:31:41
 Re: F 20 rear wheel bearing in reply to wes in PA, 10-30-2005 19:34:43
Thanks Wes I didn`t know it would be that easy. Thought maybe the gear would be pressed on. Thanks, Everett
