My new toy.
VAJerry
10-30-2005 18:26:09
third party image
Being they are getting rare I think the best thing is to turn her into a trailer queen. What do you think?
MJin the UK
11-01-2005 02:19:50
 Re: My new toy. in reply to VAJerry, 10-30-2005 18:26:09
IH made this baler in the UK as the B55T twine tyer and B55W as a wire twister. In the late 1960s i used to work one with a B450 tractor. The B55W had a BD144 diesel engine for a power unit and the B55T was PTO driven. We used average 28 hay bales to the ton. MJ
Lance R.
10-31-2005 13:42:23
My brother has two 55T balers for parts. The engines are both gone but there are still many usable parts. Your's appears to have the "C" engine. Our 55T had the Cub engine which he just parted with a few months ago. This was the largest baler IH made at the time and these bales really stacked well. We only put 64 bales per load most of the time and use the hay forks to loft eight bales at a time into the barn. Only problem was they broke the floor joist once when we triped the forks with the trip rope.
Dr.EVIL
10-31-2005 08:33:03
Neighbor Dad traded help with had a 55T for MANY years, engine driven like that one. His was hand-crank start. I used to get carried away making HUGE windrows since I could slow down or stop to feed in the windrow. When He got a #37 PTO baler I had to learn how to rake hay ALL OVER again.
Bruce Wa.
10-31-2005 06:03:56
This is the baler we had when I was young. Very heavy. Pulled with an H and if the ground was a little soft the engine side would sink. Saw it stuck many times. Put a dual wheel attachment on but made it quite wide.
Bruce Wa.
10-31-2005 06:08:06
 Re: My new toy. in reply to Bruce Wa., 10-31-2005 06:03:56
Also they have an odd size chamber. 15x19 I believe, rather than the standard 16x18 we see today.
MACE
10-31-2005 04:34:38
Give us some info on this new toy. What make and model is it for those of us who don"t know? It would look good behind my A as well. Post more pictures if you can. I"m sure everyone would like to see more of it.
MACE
gene bender
10-31-2005 03:15:30
I dont see the starter or is the pic not that clear?
leon
10-31-2005 05:10:25
 Re: My new toy. in reply to gene bender, 10-31-2005 03:15:30
Looks to me like the starter is right there below the oil filter along side the block at just about the oil pan to block joint level.
Darald Marin
10-30-2005 18:39:15
Yes I think you should save this baler. My uncle had one new in the late 40's and I remember him pulling it with a new Ferguson. His was a 55T with the front wheel. Looks like a good restoration.
VAJerry
10-30-2005 18:46:48
 Re: My new toy. in reply to Darald Marin, 10-30-2005 18:39:15
Im gonna put together a front wheel for this. Should look good behind the Super A.
Evan350
10-31-2005 12:36:06
 Re: My new toy. in reply to VAJerry, 10-30-2005 18:46:48
So, I see other people reminiscing about model 55's but is the pictured baler a 55? How does it differ from the 45? (larger chamber? higher plunger speed? wider pickup?)
Dr.EVIL
10-31-2005 13:55:52
 Re: My new toy. in reply to Evan350, 10-31-2005 12:36:06
Yes.... Just all around a MUCH heavier built baler. And the picture shows the 55T decal just above the hitch.
Evan350
11-01-2005 08:10:47
 Re: My new toy. in reply to Dr.EVIL, 10-31-2005 13:55:52
Now that you mention it, I see the 55T lettering. Anyway, I have two 45's, one dead, the other still limping along.
Gamitch
10-31-2005 18:15:29
Pretty good chance that's a C-153. It sure looks like one.
