350 lift
bedrock1234
11-01-2005 04:42:04
I have a Farmall 350 and the rear lift will not stay up I havse not tried it with a load since I just changed a couple of the hyd control blocks and put in new o rings. I hate to take it back apart as I just finished painting it. I do need it to hold a load as I use this thing all the time, but if I have to, I have to. Thanks in advance for any help.
Dellbertt
11-01-2005 08:16:58
 Re: 350 lift in reply to bedrock1234, 11-01-2005 04:42:04
Check the fluid level and cycle the system several times including whatever else is hook to it. May be just lots of air in system.
ACES
11-01-2005 05:04:02
Bedrock Could be bad seals in the cylinder, or the control valve litting oil lead by spool, in which case you may need to add check valve in the line,or if you have sheck valve maybe it leaking.
Evan350
11-01-2005 06:48:14
 Re: 350 lift in reply to ACES, 11-01-2005 05:04:02
Yea, make sure the check valve is OK. This is the block on the battery case with the hardlines to the front (to the spool valve) and the flex lines going to the cylinder.
