is the hydro system closed on the Super A?
fenton
11-01-2005 07:03:27
On the Super A is the hydro system closed? I had to add fluid as it was quite low and didn't want to raise the plow, so I added up to the fill level, or just below as it asked to but I was sure it wasn't that low when I first brought her home. There is no fluid on the floor so I quess it was pretty darn low in the first place. I will keep an eye on it, but can it leak into anywhere else where iy wouldn't show?? Thanks as always.
Dellbertt
11-01-2005 08:06:13
 Re: is the hydro system closed on the Super A? in reply to fenton, 11-01-2005 07:03:27
If you decide to change the seal ask your dealer for a parts pictorial copy of your pump. Its a lot easier when you get a visual on how it comes apart.
El Toro
11-01-2005 07:16:57
It's a closed system. Keep an eye on the engine oil level, your hydraulic oil may be leaking into
the engine. Hal
MikeEB
11-01-2005 07:14:37
Check the oil level in the crankcase. If it is leaking, it is leaking into the crankcase. The seal in the hydro pump would then have to be replaced.
fenton
11-01-2005 07:41:55
 Re: is the hydro system closed on the Super A? in reply to MikeEB, 11-01-2005 07:14:37
How hard is it to repalce the seal to the hydro pump?
MikeEB
11-01-2005 07:45:50
 Re: is the hydro system closed on the Super A? in reply to fenton, 11-01-2005 07:41:55
It is not a real difficult job. The hydro fluid needs to be drained. The tubing into the pump (2 bolts) needs to be removed, the pump removed from the block (2 more bolts). The pumb needs to be taken apart (2 bolts again). You can purchase the seal by itself or buy a pump rebuild kit which includes all the gaskets.
fenton
11-01-2005 07:53:19
 Re: is the hydro system closed on the Super A? in reply to MikeEB, 11-01-2005 07:45:50
Sound pretty atraight forward...I'll check the levels and see if it is indeed leaking. Hope not...but at least you can work on these old gals without being a master mechanic.
Peabody
11-01-2005 12:24:10
 Re: is the hydro system closed on the Super A? in reply to fenton, 11-01-2005 07:53:19
Start-to-finish, 30-45 minutes, last time I did mine.
