farmall a clutch question
upred
11-02-2005 16:39:12
when I push in the clutch on my A, I feel like something is hitting a gear. Possibly the ring gear, I recently had the tractor split and I replaced the brass bushing. It only happens when I push the clutch in all the way and I don't have any problems shifting -- any Ideas???
Thanks Rick
MagMan
11-02-2005 17:14:32
 Re: farmall a clutch question in reply to upred, 11-02-2005 16:39:12
I dont know the smaller tractors that well but I think you will have to adjust it so it does not ingauge so far happened on my Cub. I think the levers on the pressure plate are hitting. But Could be wrong. JON
MagMan
11-02-2005 17:16:01
 Re: farmall a clutch question in reply to MagMan, 11-02-2005 17:14:32
I also have a brand new set of springs and levers and pins for an A or B pressure plate cheap if you are interested. JON
upred
11-02-2005 19:37:38
 Re: farmall a clutch question in reply to MagMan, 11-02-2005 17:16:01
Thanks Maq Man, I'll try and adjust it first
