Steel wheels
mpriar
11-03-2005 11:16:55
Guys, where can I get the treads to bolt onto steel wheels? I have taken the lugs off but do not know where to go for the treads for the front or back.
Thanks
Sloroll
11-04-2005 05:20:06
 Re: Steel wheels in reply to mpriar, 11-03-2005 11:16:55
Miller tire sells em I think.
Kirk in PA
11-03-2005 16:33:10
I went to a tire recapper for front tread. Had exactly the right width. Bought it by the foot and it worked great.
Maark
11-03-2005 12:55:20
Just find some old rear tires, use a sawsall to cut the sidewall off and trim the tire to fit your needs. Most tire stores would give you tires with a bad sidewall or something else wrong to get them out of their sight.
fluggie in IA
11-03-2005 14:27:37
 Re: Steel wheels in reply to Maark, 11-03-2005 12:55:20
When you use the sawzall, get the new "dual direction" cutting blade. They really speed up the process and lamost cut without any pressure from you.
