Tach overhaul
skipper
11-04-2005 06:37:59
Well, I am getting closer to starting on the restoration of my dads Farmall 350. The tach is frozen at the cable side. Does anyone know where a good place would be to send it to get it fixed? Thanks in advance,
Skipper
Maark
11-04-2005 09:12:08
 Re: Tach overhaul in reply to skipper, 11-04-2005 06:37:59
Nick Barbieri in Merrick, New York does JD tach's. Might give him a call. ph.# is 516-221-4116
DC-TX
11-04-2005 09:00:03
Might try www.samstractor.com. He has them for $65.00, unless you want original IHC items.
REDEYE
11-05-2005 04:45:46
 Re: Tach overhaul in reply to DC-TX, 11-04-2005 09:00:03
I just checked that link out as I need a tach myself. It says there for 300-350 utility. That tach should fit all 300, 350, 400, 450 gas tractors as they should all have the same tach right?
Farmall450man
11-04-2005 08:45:05
Bates will rebuild it, but I understand they charge a price that some consider high. Too each their own. You might also try a local speedo shop as they should be able to work on it. Have them calibrate it so that it runs at the correct rpm.
