DEAD PTO ON 806
HARLEN L
11-04-2005 19:03:32
I RECENTLY BOUGHT AN 806 AND JUST REALIZED THE PTO DOES NOT WORK
RUNNING THE LEVER BACK AND FORTH DOES NOTHING,ALMOST LIKE IT IS UNHOOKED
CAN ANYONE GIVE ME SOME IDEAS OR TELL ME WHAT KIND OF MESS I'LL HAVE IF I START PULLING IT APART
I AM VERY MECHANICAL BUT HAVE NEVER WORKED MUCH ON THESE TRACTORS THANKS IN ADVANCE FOR ANY HELP YOU CAN GIVE, HARLEN
HARLEN L
11-07-2005 18:02:23
 Re: DEAD PTO ON 806 in reply to HARLEN L, 11-04-2005 19:03:32
OK, I DECIDED TO TAKE THIS THING TO THE IH DEALER AND JUST LET THEM FIX IT. I FIRED IT UP TO DRIVE THE EIGHT MILES TO THE DEALERSHIP. THEN WENT AROUND THE BACK TO HANG AN SMV EMBLEM. THE PTO WAS RUNNING. I GUESS I LEFT IT ON WHEN I WAS PLAYING WITH IT. I TRIED IT MANY TIMES AFTER THIS ON AND OFF, IT WORKS JUST FINE. HOW DO YOU EXPLAIN THAT? I GUESS I'LL JUST USE IT AND SEE WHAT HAPPENS. THANKS FOR ALL THE HELP!!
HARLEN L
11-06-2005 15:47:47
OK TIME FOR A STUPID QUESTION
WHAT IS THE IMPORTANCE OF CHECKING THE PRESSURE JUST BECAUSE I CHANGED THE PIN? CAN I GET TO THE PIN JUST BY REMOVING THE REAR COVER THAT THE SHAFTS RUN OUT OF OR IS THIS A MAJOR TEAR DOWN?
the tractor vet
11-06-2005 16:32:53
 Re: DEAD PTO ON 806 in reply to HARLEN L, 11-06-2005 15:47:47
Because when ya unscrew the top nut it changes the pressure as that is how you adjust the pressure by screwen the nut up or down Up to raise pressure and down to reduce it and ya want to set it as i have alway done it on them at around 245-260 this will make sure that you never slip thru the clutch pack and if ya go to high it can either warp the clutch pack or blow out the clutch pack snap ring. That is why i gave you the part# of the fitting now one guy said that you can drill out a bolt and use that well maybe so but i would and never had done that as when ya work on other peoples tractors it had better be wright all it takes is one bad job to ruin a reputation , does not matter how many good jobs ya do it only takes one that is why i have give ya just about all that ya need to fix a PTO and advised you to get and I T manual as i did not tell ya everything i figured if ya wanted more you would ask.
Aces
11-05-2005 12:33:50
Harlen you could drill a hole in a matching screw and make a fitting but the threads for the port are extra fine I don't think you will find a screw to fit. The little pin is where I would look fitst. The valve has to go out the bottom of the pto.
Bob
11-04-2005 21:27:50
There's a little pin that holds two parts of the PTO operating valve together down inside the valve body.
When it breaks, the lower part of the valve spool is not raised up, to actuate the PTO, when the upper part is pulled up by the linkage from the PTO lever.
It's pretty easy to replace, a service manual with an exploded view would help, though.
It's important to check the PTO clutch operating pressure after repairs are made.
the tractor vet
11-05-2005 06:51:34
 Re: DEAD PTO ON 806 in reply to Bob, 11-04-2005 21:27:50
But to do that he needs the special fitting and that is not that easy to come by Part # 384328R1 then he needs a gauge that will read atleast 600 lbs. and sometimes ya have to remove the drawbar support to drop the valve out .
Bob
11-05-2005 08:17:49
 Re: DEAD PTO ON 806 in reply to the tractor vet, 11-05-2005 06:51:34
The adapter fitting for the gauge is simple to make, though. Drill a small hole in a natching bolt, then braze a coupling to it.
the tractor vet
11-05-2005 16:10:58
 Re: DEAD PTO ON 806 in reply to Bob, 11-05-2005 08:17:49
Well Bob since it is a Hdy fitting plug WITH and O/RING it is sorta hard to find a bolt with the thread size and a grove for the O/RING now isn't it . Now if ya had the plug you could drill and weld and screw around , But the kicker is tryen to find and extra PLUG of that size but you could run over to your neighbors tractor and borrow his .
rif
11-05-2005 09:44:06
what is a natching bolt?
rif
