Super MTA Farmhand Loader Cylinder Leak
Ron Smith
11-06-2005 04:32:48
I have an old Super MTA that has a Farmhand loader on it with a trip lever-narrow front end. The old loader has worked great through the years and it has seen a lot of use. One of the cylinders is leaking hydraulic fluid very rapidly all of a sudden though. Looks like the seal is blown out. Can these be rebuilt? Looks like it will unbolt on the end. It has a clamp over the end close to the seal. Can't really use the bucket right now; it shoots such a stream. I can get the cylinder off easy enough, but don't know what I am looking at as far as a fix or maybe a replacement is the route to go.
El Toro
11-06-2005 06:26:44
 Re: Super MTA Farmhand Loader Cylinder Leak in reply to Ron Smith, 11-06-2005 04:32:48
Those cylinders probably need to have repair kits
installed in them. Your local Case/IH dealer may have the kits and could probably rebuild your
cylinders if you don't feel comfortable doing it.
Here's a web site for Farmhand. Hal
http://www.farmhand.agcocorp.com/
