cheap ways to maake a farmall m pull better
zach lewter
11-06-2005 17:03:59
I would like to know how to get a farmall m to pull better but it needs to be a cheap way
Fluggie in IA
11-07-2005 10:48:34
 Re: cheap ways to maake a farmall m pull better in reply to zach lewter, 11-06-2005 17:03:59
The biggest thing I found out while pullin' is it's more in the "bite" than in the ponies. If she's running good, spend $$ on getting the right type and widest allowed tires, get your hitch set exactly right, give her just a few more "R"s and you'll have a blast and likely will pull with the top guys. After that gets you hooked, then spend the bigger bucks on the engine. Have fun tho . . .that's the first rule!
ChadS
11-07-2005 09:58:38
Buy a 450 engine kit, pull out the dry sleeves out of the M block, run the pistons on the block, use a 450 head gasket and go pulling, good cheap way to pick up 10 hp. You could do that as an inframe overhaul, and the price of an inframe overhaul. Now, you could spend a little more and bore the M block to fit the 450 sleeves and have the block renewable upon rebuilding years down the road,, But you said cheap,,, so thats what I would do. Add a 450 cam to it, and you would have a 450 engine in the M,, for less that 500 bucks. that could make anywhere from 63-70 hp if you do it right. ChadS
BillyinStoughton
11-07-2005 07:17:16
I've helped mechanic on a 600 HP Mini-Rod for the last five years...and if I have learned one thing about pulling (if you want to be competitive) CUBIC DOLLARS BABY, NOT CUBIC INCHES! Pulling is the most expensive way to travel 300 feet. Sorry! Start with the inexpensinve stuff if you want (governor work, ignition performence, fuel systems), but sooner or later it's gonna boil down to a 450 cam, a good set of valve springs, a set of Firecraters, and some head work! Keep your chin up!
supermpuller
11-06-2005 17:09:02
Son if you want to play its going to cost money, nothing is free.
zach l
11-06-2005 17:18:54
 Re: cheap ways to maake a farmall m pull better in reply to supermpuller, 11-06-2005 17:09:02
Thank you anyway .I have money I am just looking for a cheaper way to upgrade my tractor.
the tractor vet
11-06-2005 18:22:42
 Re: cheap ways to maake a farmall m pull better in reply to zach l, 11-06-2005 17:18:54
There is NO CHEEP WAY HORSE POWER COST MONEY anyway ya cut it . A good tune up now i am talken about adjusten the valves going over the dist and maken sure that the dist has had the upgrade done on it at one time and assummen that the engine is in good shape ya may get a couple more ponys .
REDEYE
11-06-2005 19:32:04
 Re: cheap ways to maake a farmall m pull better in reply to the tractor vet, 11-06-2005 18:22:42
What is the distributer upgrade?
Shaggy
11-06-2005 21:28:33
 Re: cheap ways to maake a farmall m pull better in reply to REDEYE, 11-06-2005 19:32:04
I was told to put light tension springs out of a recurve kit for a chevy and that would help it advance quicker.
the tractor vet
11-06-2005 19:55:38
There was and update on the Older M and H dist. that cut the advance back it was a weight and spring kit . Made for better luggen . And wright now off the top of my head i don't remember just who much it cut them back but was good for about 4-5 ponys .
supermpuller
11-06-2005 17:29:45
Get more compression, firecrater pistons, take a little off head, make sure its a 8060 or newer, 450 cam, 450 or lp intake and exhaust manifolds,electronic ignition , rejet carb and adjust carb and motor to specs I use 386 autolite plugs, that ought to give you a start.
Nat
11-07-2005 04:34:13
 Re: cheap ways to maake a farmall m pull better in reply to supermpuller, 11-06-2005 17:29:45
But that's not cheap to do, unless you steal the parts.
supermpuller
11-07-2005 09:09:24
 Re: cheap ways to maake a farmall m pull better in reply to Nat, 11-07-2005 04:34:13
I have 4.125 firecraters if anyone needs a set, and no they aren"t free.
