Farmall M cooling system capacity
Ross in QLD
11-06-2005 18:20:43
Just wanting to know the cooling system capacity of a Farmall M. Thanks Ross
jms1066
11-07-2005 15:45:05
 Re: Farmall M cooling system capacity in reply to Ross in QLD, 11-06-2005 18:20:43
when its full it will run out the top lol sorry i think its about 4-5 gal if its just the raditor
El Toro
11-06-2005 18:46:29
That is 6 gallons of coolant. Hal
Janicholson
11-07-2005 06:21:11
 Re: Farmall M cooling system capacity in reply to El Toro, 11-06-2005 18:46:29
Needing to add.
A system flush is profoundly appropriate, they tend to buildup a layer of gunkie brown rusty stuff in the lower cylinder jackets.
I like the newer Universal coolants with corrosion inhibitors that are advanced compared to plain old antifreeze. 50/50 mix.
JimN
El Toro
11-07-2005 07:25:31
 Re: Farmall M cooling system capacity in reply to Janicholson, 11-07-2005 06:21:11
I just did that yesterday. I drain & flush every other year and put in a 50/50 mix of Zerex.
Permanent doesn't mean forever either.
We used Zerone, an alcohol base antifreeze years ago. We installed it in the Fall and drained it in the Spring. Never had a radiator problem or a cooling problem. Hal
