char-lynn project
tn terry t
11-06-2005 18:58:46
hello folks i have goten all my power=sterring parts except one just about ready to pull granny H in the shop. the charlynn unit has woodruff keys cut in both ends of the shafts but the steering shaft extender and the other coupling that i got from steel wheel ranch was not cut for woodruff keys only has 5/16 through holes for roll pins should i take the time to have them cut or will the roll pins be ok? the pins seem a little weak to me but i tend to over build everything what you guys think?
Bob M
11-06-2005 19:33:00
 Re: char-lynn project in reply to tn terry t, 11-06-2005 18:58:46
terry - My Super M Charlynn PS has only the roll pins. However there's actually TWO roll pins in each hole. A second, smaller diameter roll pin is driven inside the 5/16" pin after it is inserted.
When I had mine apart several years ago I replaced all (4) roll pins. I forget the size of the smaller pins now, but it is a standard size available at NAPA, etc.
tn terrt t
11-06-2005 20:11:10
 Re: char-lynn project in reply to Bob M, 11-06-2005 19:33:00
oh! thank you very much mr bob i knew you would be there to help me out again maybe i wont have to bother you again on this subject
