Hydraulic Problem on 400D
Farmall Frank
11-07-2005 09:22:46
I have a fast hitch. The rod on the cylinder that controls the angle of the hitch (mechanism under the tractor on the right side) slowly pulls out as I plow. When I attempt to have it return, the pump reacts with anguish and the rod refuses to return. However, if I reverse the control and immediately again attempt to return the rod, it works.
What is the problem? Thanks.
Janicholson
11-07-2005 09:42:19
 Re: Hydraulic Problem on 400D in reply to Farmall Frank, 11-07-2005 09:22:46
I will make a guess that the spool valve (I think it is the middle one on the dash) is not centering. may be worn in the pin, or spool end.
Others may have had the problem.
JimN
Farmall Frank
11-07-2005 12:43:44
 Re: Hydraulic Problem on 400D in reply to Janicholson, 11-07-2005 09:42:19
The controls are pretty floppy. Might be a good winter project to repair the controls, if possible.
