Will 12 Volt fit?
M Battery Box
11-07-2005 10:53:16
Need battery box for 40's M. Rig has been switched to 12 V. Has new Interstate 12V battery w/ no box. Will it fit inside replacement box sold on this site? Thanks.
DigDugNC
11-08-2005 22:31:44
 Re: Will 12 Volt fit? in reply to M Battery Box, 11-07-2005 10:53:16
Some one was kind enough to measure their battery box on this site and give me the dimensions so I could buy a battery now that will fit in the box I plan to replace later. I believe the dimensions were 7 1/2" wide x 11 1/2" across x 9 1/2" high.
Hobo,NC
11-07-2005 17:56:53
Interstate group 35 izz close to a group 1 and a group 25 or 26 will werk not sure weather its a 25 or 26, I use the 35 to replace a group 1, 6 Volt battery.
Wild Bill
11-07-2005 11:49:55
A "Group One" automotive 12 volt battery will usually fit into most 6 volt battery boxes, at least they have in my past experiences (many 40's an 50's large and small trucks, vehicles, and tractors.) I bet you can email for the exact size of the box, then measure your battery to check the fit. So there is a "meaningful answer"
RustyFarmall
11-07-2005 12:26:09
 Re: Will 12 Volt fit? in reply to Wild Bill, 11-07-2005 11:49:55
My 1940 M is 12 volt, when the battery went bad I pulled one out of a 1968 Ford pickup that is no longer being used, the battery fit right into the original battery box, and I even had to cut some pieces of one inch lumber to fill up the space around it and under it.
Janicholson
11-07-2005 11:10:46
Well there is no answer.
The physical size of your battery is unknown, so we cannot respond meaningfully.
If you are not interested in originality, a marine plastic battery box with lid is reasonable, and durrable. Buy one to fit the physical dims of your new battery.
JimN
Harley
11-07-2005 16:45:36
 Re: Will 12 Volt fit? in reply to Janicholson, 11-07-2005 11:10:46
My dad has run one for years with an elasticated hold down device with chromium plated "S" hooks on each end and it seems to work for him. :-) Harley
