How do I split my tractor
Eamonn
11-07-2005 13:26:46
Does any1 know how i can split my International Harvester434. I have it almost split, I have all the bolts out but there seems to be something stopping it from splitting. It is although a shaft or something is stopping it?
JB2
11-07-2005 19:20:27
 Re: How do I split my tractor in reply to Eamonn, 11-07-2005 13:26:46
Hi Eamonn, you sure you got all the bolts out?
There are usually 2 hidden under the battery box. Then there are usually 4 guide pins, 1 on each side and 2 at the top. These guide pins fit snuggly and can be stuck in the holes.
The other thing that can keep it from coming apart is if one of the clutches have worn a grove in the spline shaft. This requires removing the bolts that hold the pressure plate to the flywheel so the clutches stay with the transmission half. The bolts can be accessed thru the inspection hole at the bottom of the bellhowsing.
Hope you have the tractor well supported, be sure to wedge a block of wood on each side of the front axle between the axle and the bumper stop to keep the enginge part from rotating when it separates from the transmission part.
Another trick I have used to separate the 2 halves is to let both supporting jacks down by 1/4" to 1/2" and this will cause the bellhowsing to separate from the engine block at the bottom, now wedge 2 flat bladed screw drivers in the crack, one on each side of the tractor, then raise the jacks by 1/2" to 1" until a crack appears at the top of the bell howsing, then wedge 2 more screw drivers at the top and lower the jacks again until the gap widens at the bottom. Repeat the procedure until the 2 halves clear the guide pins. If you have a floor jack under the engine part and once the guide pins are clear and with the rear wheels blocked, you can usually roll on the front wheels and the engine part will roll away from rear end.
BE CAREFULL NOT to lower or raise the 2 halves to far off center as their is a great stress applied to casting around the guide pins. Do not want to crack casting.
BE VERY CAREFULL make sure you have a secondary means of supporting the tractor halves if one of the jacks do slip. We usually make a support out of 4x4s.
Good Luck
JB2
lee
11-07-2005 15:50:50
post more what you've done and how are you doing it. Has it begun to split at all? How are you supporting it? Have you gone below and unbolted the pressure plate from flywheel?
Harley
11-07-2005 16:39:10
 Re: How do I split my tractor in reply to lee, 11-07-2005 15:50:50
third party image
There are several ways to accomplish this feat, and here is a picture of one way to do it, but maybe this isn't what you had in mind, Harley
lee
11-07-2005 19:19:20
 Re: How do I split my tractor in reply to Harley, 11-07-2005 16:39:10
well' ya oughta know better than to take it out and go to work with all the bolts out!
farmallhal
11-07-2005 18:05:53
Harley, That background looks quite a bit like Missouri just east of Springfield. Is this very close to your backyard? Could this be one of the M's I saw at the Republic Steam Show? Just couldn't leave this one alone. Have a good one and hope your fall down your way is as nice as we are having up north 100 miles or so. Hal
Robhkent
11-07-2005 16:51:22
Now that is a good way to scare a guy... Is that a personal experience pic Harley??
Rob
Harley
11-08-2005 18:25:23
 Re: How do I split my tractor in reply to Robhkent, 11-07-2005 16:51:22
Na I just stole that from the stuck and troubled files. We don't have 2 acres that flat down here on the ridge. Yep Hal, we been riding the Harley every weekend so far, but one of these days this weather is gonna bite us right in the arse, Harley
